Laguna
Laguna Halogen Double Arm Light
SKU: 111769
£69.98 £155.98 Save £86.00
£58.32 Excl. VAT
  • Bright light provides clear illumination for detailed work
  • Secure hold ensures the light stays in place during use
  • Quick setup makes installation easy with 60 mm mounting holes
  • Pair with the Axminster magnetic mount for maximum flexibility
The Halogen Light Double Arm is the perfect addition to your workshop. This versatile light fixture is designed to provide optimal illumination for many machines like bandsaw and lathes, ensuring you have a clear view of your workpiece at all times. With its double arm design, you can easily adjust the light to focus on specific areas, enhancing precision and safety.
The Laguna Light offers several advantages over traditional overhead lighting. Firstly, its bright, clear halogen illumination enhances visibility, allowing you to see every detail of your work. This is particularly beneficial for intricate tasks that require precision. Secondly, the double arm design provides greater flexibility and precision in positioning the light. The long articulating arm allows you to adjust the light to various angles and positions, ensuring that you can direct the illumination exactly where you need it.
For even greater convenience and flexibility pair the Laguna Halogen Light with the Axminster Magnetic Mount (SKU 510345 sold separately). This dynamic duo offers unparalleled convenience and flexibility, allowing you to easily attach and reposition the light on any metal surface, providing optimal illumination exactly where you need it.
Corded or Cordless Corded
Cable Length 1.8 m
Plug Fitted UK 3 pin plug
Web Attribute Set General Machine Accessories
EAN Barcode 5052511135523
