Lamello
Lamello LC P-16 x 17 Connector Set 80 and Clamex P-14
SKU: 113436
£189.98 £199.98 Save £10.00
£158.32 Excl. VAT
  • Suitable for 17mm panels
  • Includes 80 connectors and Clamex P-14
  • For jointing in lightweight panel construction
  • Part of the Lamello P-System
  • Robust and flexible connection
  • Connector allows for assembly and disassembly
  • Secure joint requires no clamping
  • Single 6mm hole operates joint connection
  • Cut with either Zeta jointer or CNC
The Lamello LC P-16 Connectors are part of the renowned P-System by Lamello, designed to provide seamless and efficient joining solutions. These connectors are specifically engineered to combine the advantages of lightweight construction with the efficient and aesthetic Clamex connection. The LC P-16 acts as an adapter into which a Clamex P-14 connector is slid, making it a versatile and robust solution for various applications. Simply cut the joint for the connector using a Lamello Zeta jointer or CNC router.
The Lamello LC P-16 x 17 Connector Set 80 with Clamex P-14 is designed for lightweight panels with a thickness of 17mm. It includes 80 connectors and the Clamex P-14, providing a secure and versatile connection solution. This set ensures a strong and reliable connection for medium-thickness panels, making it ideal for various lightweight applications.
The Lamello LC P-16 x 17 Connector Set 80 with Clamex P-14 includes the following components:
80 LC P-16 x 17 Connectors: These connectors are specifically designed for lightweight panels with a thickness of 17mm. They provide a secure and reliable connection, making them ideal for various lightweight applications.
Also, Clamex P-14: This is an additional connector that complements the LC P-16 system, offering versatility and flexibility in design. This set ensures a strong and reliable connection for medium-thickness panels, making it suitable for furniture and kitchen manufacturers, joiners, and carpenters who work with lightweight materials.
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640348841021
