Lighthouse
Lighthouse 2,000 Lumens Rechargeable Worklight
SKU: 114757
£24.98 £29.99 Save £5.01
£20.82 Excl. VAT
  • Up to 2,000 lumens output
  • 360° rotating LED head
  • Three brightness settings
  • 6000mAh rechargeable Li-ion battery
  • Up to 8 hours runtime
  • Foldable design with magnetic mounting & hook
  • Bright 6500K daylight colour temperature
  • IP44 rated for dust and splash resistance
The Lighthouse 2,000 Lumen Rechargeable Work Light delivers powerful 360° illumination for workshops, garages, construction sites and DIY projects. Featuring a rotating LED head with three brightness settings, it provides up to 2,000 lumens of daylight-quality light to suit a wide range of tasks.
A lightweight folding design allows the light to be used free-standing, mounted or positioned exactly where needed. Integrated magnets and a hanging hook provide additional mounting options, while the 6000mAh rechargeable Li-ion battery delivers up to 8 hours of runtime. Producing a bright 6500K daylight-colour light, it is ideal for detailed work. USB-C charging and integrated USB-A and USB-C output ports allow compatible devices to be charged directly from the unit, adding extra versatility for both professional and home users.
Lighthouse is renowned for producing reliable, high-performance lighting solutions designed for trade, workshop and outdoor use.
Supplied with; 2,000 Lumen rechargeable work light, USB-C charging cable
Battery Capacity 6,000 mAh
Battery Voltage 3.7 V
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969015231
