Perform
Perform PD216SMS Slide Mitre Saw 230V
SKU: 113594
£112.49 £149.98 Save £37.49
£93.74 Excl. VAT
  • Ideal entry-level or light use mitre saw
  • Forward‑facing bars save space when placed against a wall
  • 1,500W motor delivers smooth, accurate cuts
  • Shadow line shows exact cutting path
  • Mitres 0-47 both ways, bevels left 0-47
  • 305mm cutting width with extension bed supports
  • Teflon coated 36T negative rake blade made by Axcaliber supplied
  • Dust bag and vacuum extraction port included
The Perform PD216SMS Slide Mitre Saw is a compact tool designed with cutting versatility and space saving in mind. Featuring a forward facing guide rail system, this saw can be positioned closer to the wall - ideal for workshops with limited floor space.
Equipped with a 1.4kW motor and a 216mm diameter blade, the PD216SMS delivers a blade speed of up to 5,000rpm, enabling smooth and precise cuts across a variety of materials. The Teflon-coated blade offers contract-grade performance straight out of the box.
This mitre saw supports a wide range of cutting angles, mitring from 0 to 47 in both directions and beveling to the left from 0 to 47, making it suitable for a variety of angled cuts. Trenching cuts can be achieved by adjusting the depth stops. Achieve precise cuts with the mitre saw's shadow line, clearing indicating the exact cutting path for easy alignment. Use the clamp to securely hold the timber in place, preventing any movement and enhancing safety. With a generous cutting capacity of up to 305mm wide and 80mm deep, the saw also features left and right pull-out extension bed supports for handling longer lengths of timber.
To help keep your workspace clean, a dust bag is provided or there's a 38mm dust extraction outlet that you can connect to a vacuum extractor.
Ideal for tasks such as decking, trim, moulding, and other indoor or outdoor woodworking projects, this saw is perfect for beginners or as a reliable, light-duty addition to any workshop.
Please note, if you require an EU plug, please ensure you purchase 113504
Bevel Angle Range 0 - 47
Dust Collection Dust Bag Supplied
Dust Extraction 38 mm Outlet
Mitre Angle Range 0 - 47
Overall L x W x H 725 x 465 x 500 mm
Spindle Lock Standard Feature
Table Size 420 x 110 mm
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 92 dB(A)
Corded or Cordless Corded
Blade RPM 5,000 rpm
Sound Pressure Level LpA [Uncertainty K] 104 dB(A)
Motor Power 1,500 W
Plug Fitted UK 3 pin plug
Web Attribute Set Mitre Saws Mains Powered
EAN Barcode 5052511143245
