Rider
Rider No. 80 Cabinet Scraper
SKU: 107351
£14.98 £28.98 Save £14.00
£12.48 Excl. VAT
  • Used to produce a precise even finish, smooth difficult grain on large areas
  • Adjusting nut varies the bite of the blade
  • Fine grey iron casting with machined base
  • 70 mm(2-3/4) wide blade
The Rider No. 80 cabinet scraper produces a clean even finish and is ideal when used to smooth difficult grain over large areas. Tightening the knob, behind the blade, causes a slight bow in the blade. This increases the bite and hence the thickness of shaving. The body of the No. 80 is a fine, grey, iron casting with a flat, machined base. The base measures 90 mm(3-1/2) x 68 mm(2-5/8), the blade is 70 mm(2-3/4) wide.
Rider planes only require the bare minimum of initial preparation. The blade is oil quenched, high carbon spring steel, hardened and tempered to HRC 63, and only requires a little honing and turning a burr before use. We are confident that Rider planes represent a good standard in traditional, quality plane manufacture and great value.
Plane Sole Length 68 mm
Web Attribute Set Hand Planes
EAN Barcode 5052511122288
