Sale Web exclusive
Roughneck
Roughneck Heavy Duty Wire Brush Set 3
SKU: 114470
£8.98 £14.38 Save £5.40
£7.48 Excl. VAT
  • Removes paint, rust and debris from hard surfaces
  • Suitable for patios, BBQs, brick, wood and metal
  • Includes 3 carbon steel wire brushes
  • Covers general, corner and heavy‑duty cleaning
  • Soft‑grip handles for comfort and control
This Heavy‑Duty Wire Brush Set is ideal for removing paint, rust and debris from hard surfaces, as well as for cleaning smaller components such as spark plug contacts. Suitable for use on patios, barbeques, brickwork, woodwork and metalwork, the set covers a wide range of cleaning tasks.
The set includes three carbon steel wire brushes:
A 300mm Carbon Steel Wire Brush with four rows of anodised bristles, designed for general‑purpose cleaning. Fitted with a comfortable TPR soft‑grip handle and scraper, it is ideal for tackling paint, rust and surface contamination.
A Heavy‑Duty Tapered Block Wire Brush, designed for accessing corners and confined areas. Featuring 18 sets of robust carbon steel bristles and a soft‑grip handle, it is suitable for general cleaning on a variety of surfaces.
A Heavy‑Duty Two‑Handed Wire Brush, designed for larger areas where extra force is required. It features two soft‑grip handles for improved control and comfort, along with 32 sets of large carbon steel bristles for efficient material removal.
Web Attribute Set Hand Wire Brushes
EAN Barcode 5057902520940
