Veritas
Veritas Miniature Shoulder Plane
SKU: 952802
£44.63 £46.98 Save £2.35
£37.19 Excl. VAT
  • Weight only 48g, 63.5mm long by 6.3mm wide
  • Fully functional, easy to manoeuvre and control
  • Effective for fine trimming or cleaning the bottoms of narrow dados
  • Stainless steel body accurately machined and surface ground
  • Stainless-steel Norris-style adjuster
  • A2 tool steel blade (1.5mm thick)
  • Supplied in a French-fitted embossed leatherette box
  • Made in Canada
The initial idea behind this miniature version of the Veritas medium shoulder plane was to challenge the limitations of the materials, design and manufacturing processes (not to mention the patience of the engineers!). It weighs a mere 48g and measures 63.5mm long by 6.3mm wide, it is the smallest plane Veritas have made to date. It is fully functional, comfortable to hold and easy to manoeuvre and control. A remarkably effective plane when it comes to fine trimming or cleaning the bottoms of narrow dados. Investment cast from stainless steel, the body has a fixed mouth and accurately machined and surface ground sole and sides. A stainless steel Norris-style adjuster lets you set the full-width A2 blade (1.5mm thick) with precision. Supplied in a French-fitted embossed leatherette box. Made in Canada.
Plane Sole Length 63.5 mm
Web Attribute Set Hand Planes
EAN Barcode 722356010815
