WATAOKA
Wataoka Wood Pro 90mm Narrow Flat File
SKU: 113767
£14.44 £16.98 Save £2.54
£12.03 Excl. VAT
  • Japanese-made woodworking file
  • 90mm working length
  • Approx. 3mm thickness
  • Narrow flat profile
  • Medium No.5 cut
  • Double-sided cutting surfaces
  • Rubberised handle for secure grip
  • Finish comparable to 280 grit abrasive
Wataoka Wood Pro 90mm Narrow Flat File is a Japanese-made woodworking file designed for detailed shaping, smoothing and refining in tight or hard-to-reach areas. Featuring a narrow flat profile and medium No.5 cut, it is particularly useful for precision work where a standard-width file may be too large. With a 90mm working length, 215mm overall length and 10mm width, it offers excellent control for fine woodworking tasks and intricate shaping.
The Wood Pro tooth pattern provides a positive cutting action with effective chip clearance, helping to reduce clogging and maintain a consistent cut. The narrow profile allows accurate work on smaller components, confined areas and finer details, whilst the double-sided cutting surfaces increase versatility. For best results, use light pressure and maintain contact with the workpiece on the return stroke to help reduce the accumulation of cutting dust on the file.
Featuring a 90mm working length, 215mm overall length, 10mm width and approximately 3mm thickness, this file is well suited to precise shaping and surface refinement. The finish achieved is comparable to approximately 280 grit abrasive, making it suitable for final shaping and surface preparation prior to applying paint, oil, varnish or other finishes. The abrasion-resistant rubberised handle provides a secure, comfortable grip during use.
Wataoka is a long-established Japanese file manufacturer based in Hiroshima, with a reputation for producing high-quality files that combine traditional craftsmanship with practical performance.
Ideal for woodworkers, carvers, luthiers, model makers and anyone undertaking detailed woodworking tasks, the Wataoka Wood Pro 100mm Narrow Flat File offers accuracy, control and a refined finish in a compact format.
Web Attribute Set Carving Knives, Scrapers & Chip Carving
EAN Barcode 5052511144358
