The Kapro 705 Eagle Optivision Red Box Level Set is a 4 piece set designed to provide optimal vision and precision in both bright and low light conditions. Featuring a high contrast ratio between the bubble and the vial liquid, this level set ensures clear visibility and accuracy. The bridge of the horizontal vial reinforces the profile, while the tilted vial allows for a direct line of sight. With visibility up to 8 times greater than regular vials, this level set saves you time and ensures precision. The transparent liquid in the vial will not fade, maintaining its clarity over time.
The Kapro 705 Eagle Optivision Red Box Level Set is built to withstand extreme building conditions, featuring a strong profile and shock-proof end caps for durability. The accuracy of the levels can be trusted, and the easily visible vials enhance usability. This set includes a 600mm (24
