GemRed
GemRed Digital Angle Measuring Rules
SKU: 210170
€18,00
  • Measures both the angle and length, metric and imperial scales
  • Calculates angles quickly and accurately, clear digital display
  • Easy operation with just two operating buttons
  • Locking function to transfer angles easily and accurately
  • Corrosion resistant stainless steel rules for durability
This is a 2-in-1 folding rule with a big difference, having a digital readout of the angles. Measure both the angle and length at the same time with a clear display and bold markings in both metric and imperial on the rules. The rules are made from corrosion resistant stainless steel. The battery life is around 200 hours and is protected by auto shut down after 6 minutes. They have a clever auto-start of the digital read out, this will switch on as soon as you open the rule, saving time and fumbling for a button. A serious tool for any carpentry or setting out task.
Batteries Includes 1 x CR2032
Battery Type Li-ion
Leg Length 200 mm
Web Attribute Set Angle Measuring
EAN Barcode 5052511007042
