Stanley
Stanley Roofing Square 600 x 400mm
SKU: 136296
€32,00
  • Designed for all roofing calculations and also the layout of stairs
  • Made from tempered steel, buffed and with a clear protective finish
  • 15 tables for rafter cuts, roofing pitches and rises etc.
  • Metric only, measuring 600 x 400mm
  • Graduated every 2mm, figured every 10mm
The metric roofing carpenters square is designed for all roofing calculations and also the layout of stairs. Made from tempered steel, buffed and with a clear protective finish and has 15 tables for rafter cuts, roofing pitches and rises etc. It is metric only, measuring 600mm x 400mm, graduated every 2mm, figured every 10mm on both sides.
Manufacturer Part Number 1-45-530
Web Attribute Set Builder's & Carpenter's Squares
EAN Barcode 3253561455308
