With a fine 11tpi, this tenon saw is ideally suited to mitre, or joint work where a smooth finish is highly desirable. Extra rigidity makes for a straighter cut and the long life induction hardened teeth, which cut on both the push and pull stroke, make this saw exceptionally good value for money. The bi-material handle, for improved grip, is screwed to the blade for extra strength and incorporates a 45
Stanley
Stanley FatMax Tenon Saw 11tpi - 300mm
| Manufacturer Part Number | 5-17-199 |
| Blade Length | 300 mm |
| Web Attribute Set | Tenon Saws |
| EAN Barcode | 3253565171990 |
