Designed to help protect hands and fingers while improving control at the table saw, the Microjig GRR-RIPPER 2GO is an essential safety accessory for any workshop. Its advanced kickback prevention design keeps the workpiece firmly aligned against the fence, reducing the risk of the blade catching the material and throwing it back towards the operator. The high friction grip surface provides exceptional control, minimising slippage and helping you make safer, more accurate cuts.
Ideal for woodworking and precision tasks, the GRR-RIPPER 2GO features precision cutting legs that allow a minimum cutting width of just 8mm (5/16), making it perfect for narrow rips and detailed work.
Supplied fully assembled, it includes a colour coded fence scale sticker that works alongside the GRR-RIPPER 2GO's visual guides. Simply match the colours to ensure the blade remains in the correct cutting tunnel for safer, more controlled operation.
More than just a table saw push block, the Microjig GRR-RIPPER 2GO is a versatile workshop aid that can be used across a range of machinery and applications where keeping hands safely away from cutting tools is essential. Whether you're a DIY enthusiast, hobbyist woodworker or professional tradesperson, it helps deliver greater safety, confidence and precision with every cut.
Overall L x W x H 119 x 71 x 180 mm
Web Attribute Set Saw Bench Accessories
EAN Barcode 815267011702
