Large cut capacity with high precision, constant electronics and extreme power make this 254mm saw a winner. The integrated slide carriage, table widener and table extension enable expansion for workpieces in a variety of sizes. Large support surfaces ensure safe and comfortable sawing. The 2,100W motor has a brake, soft start, overload protection and constant speed for whatever material you are cutting. Expanding worktop gives up to 635mm width and at 90 79mm depth. The rip fence is fitted with the Bosch self-aligning Squarelock for precision every time and the integrated sliding table with mitre fence will handle work up to 350mm. There is on-board storage for cables, blades and other accessories, so you have everything to hand. Integrated handles on the machine table top allow for easy transport. Supplied with 24T tungsten tipped saw blade, mitre fence, push stick and dust adaptor.
Blade Tilt -1 to 47
Dust Extraction Outlet 60 mm
Max Depth of Cut @ 45º 56 mm
Max Depth of Cut @ 90º 79 mm
Max Width of Cut with Fence 635 mm
Overall L x W x H 775 mm x 768 mm x 343 mm
Power 2.1 kW
Rating Trade/Professional
Table Height 343mm
Table Size 584 mm x 759 mm
Blade Diameter 254 mm
Blade RPM 3,200 rpm
Plug Fitted UK 3 pin plug
Web Attribute Set Saw Benches Globale Group: low-margin-eu
EAN Barcode 3165140509435
