Large cut capacity with high precision, constant electronics and extreme power make this 254mm saw a winner. The integrated slide carriage, table widener and table extension enable expansion for workpieces in a variety of sizes. Large support surfaces ensure safe and comfortable sawing. The 2,100W motor has a brake, soft start, overload protection and constant speed for whatever material you are cutting. Expanding worktop gives up to 635mm width and at 90
Bosch
Bosch GTS 10 XC 254mm Table Saw
| Blade Tilt | -1 to 47 |
| Dust Extraction Outlet | 60 mm |
| Max Depth of Cut @ 45º | 56 mm |
| Max Depth of Cut @ 90º | 79 mm |
| Max Width of Cut with Fence | 635 mm |
| Overall L x W x H | 775 mm x 768 mm x 343 mm |
| Power | 2.1 kW |
| Table Height | 343mm |
| Table Size | 584 mm x 759 mm |
| Blade Diameter | 254 mm |
| Blade RPM | 3,200 rpm |
| Plug Fitted | UK 3 pin plug |
| Web Attribute Set | Saw Benches Globale Group: low-margin-eu |
| EAN Barcode | 3165140509435 |
