DeWALT XR FLEXVOLT is a range of 54V cordless power tools offering unrivalled run time and performance. For the first time, professional trades can reliably undertake heavy-duty construction applications without the need for mains power.
The DCS7485T2 XR FLEXVOLT table saw provides you with all the performance of a mains powered saw in a highly portable, cordless power tool. The 54V FLEXVOLT battery gives you all the benefits of a mains powered saw with the freedom of a cordless tool. You can now complete the toughest jobs without trailing cables. The DeWALT DCS57485T2 XR FLEXVOLT table saw is an excellent choice for a professional working on a construction site. The DCS57485T2 comes fitted with a 210mm 24-tooth TCT blade giving you up to 65mm depth of cut. This robust cordless table saw can crosscut, bevel and rip up to 610mm wide (enough to cut an 8 x 4 sheet in half). The rip fence features rack and pinion adjustment, front and rear locks and clear scales for maximum accuracy. The quick bevel lock features a large clear scale for easy and accurate setting of bevel cuts up to 48. Below the 480 x 480mm, cast tabletop an integrated steel roll cage protects the body of the saw against job site drops and impact damage. It has a brushless motor for a long, maintenance free service life. This high torque motor provides power and durability. An overload protection system protects the battery and electrical systems.
Supplied with 2 x 54V XR FLEXVOLT batteries, fast charger, 24 tooth TCT saw blade, mitre fence, 2 x blade spanners, rip fence, dust port reducer and push stick.
Note: The XR FLEXVOLT battery is completely compatible with all existing DeWALT XR 18V products. It offers you an unprecedented 6.0Ah of power in any XR 18V cordless tool.
Battery Voltage 54 V
Blade Tilt -3 to 48
Max Depth of Cut @ 45º 45 mm
Max Depth of Cut @ 90º 65 mm
Overall L x W x H 605 mm x 605 mm x 330 mm
Rating
Table Size 480 mm x 480 mm
Blade Diameter 210 mm
Battery Type Li-ion
Blade RPM 5,800 rpm
Model DCS7485T2
Bore Size 30 mm
Max Ripping Width 610 mm
Nett Weight 22 kg
Warranty DeWALT 3 Year Warranty (Registration Required)
EAN Barcode 5035048645772
