A table saw in a Systainer, and cordless, and powerful, and accurate, and versatile; the CSC SYS 50 cordless table saw is all of these. The Systainer format makes it easily transportable particularly for mobile professionals. The CSC SYS 50 is fully compatible with the entire Festool Systainer system. This unique saw offers workshop performance on site.
Power comes from two 18V batteries (from 4.0Ah) in combination with a brushless EC-TEC motor, resulting in performance more than comparable to a mains-powered machine. NOTE: this is a body only machine supplied without batteries or charger. The brushless EC-TEC motor with high speeds of 6,800 rpm guarantees fast sawing progress.
The CSC SYS 50 allows you to make parallel rip cuts of up to 280mm wide and cross-cut widths of up to 450mm. The maximum depth of cut is 48mm and the blade tilt; from -10 to 47.
The outstanding feature has to be the digital display for both blade height and blade tilt. Select the function, then turn the knob to set the depth of cut to within 0.1mm or the blade angle to within 0.1. Reproducing cuts couldn’t be more accurate, the digital display ensures precise results. Four saw blade positions can be saved and selected via the digital display. The height and angle are electrically adjusted at the press of a button.
On the left hand side the super smooth sliding table and mitre crosscut fence allow cutting up to 450mm in front of the blade and mitre angles from -70 to +70. On the right hand side a fold down table extension and rip fence allow cuts of up to 280mm wide. The rip fence locks front and back with a single clamping lever.
Supplied with 42 tooth TCT saw blade and chip collection bag. Alternatively, it can be connected to a suitable vacuum dust extractor.
The blade guard and riving knife can be quickly removed for grooving or rebate cuts and just as easily re-installed. The Systainer lid features storage for the fences, blade guard, dust bag and spare blade.
At the end of the day the Systainer hood securely clips in place over the saw, allowing easy transportation and protection.
Table height 228mm
Cross cut width at 90 - 450mm
Cross cut width at 45 - 340mm
Cross cut width at 70 - 140mm
Parallel rip cut width - 280mm
Cutting height at 0 - 0 to 48mm
Cutting height at 45 - 0 to 34mm
Cutting height at 47 - 0 to 33mm
Cutting height at ‑2 - 0 to 48mm
Cutting height at ‑10 - 21 to 32mm
Battery Voltage 36 V (2 x 18 V)
Bevel Angle Range -10 to +47
Dust Extraction 27 mm / 36 mm Outlet
Max Depth of Cut @ 45º 34 mm
Max Depth of Cut @ 90º 48 mm
Mitre Angle Range 0 - 70
Overall L x W x H 512 mm x 396 mm x 296 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 168 mm
Sound Power Level LwA [Uncertainty K] 98 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 85 dB(A) [3.0 dB]
Saw Blade Speed 4,500 - 6,800 rpm
Manufacturer Part Number 576820
Model CSC SYS 50 EBI-Basic
Bore Size 20 mm
Kerf 1.8 mm
Nett Weight 20.2 kg (without batteries)
EAN Barcode 4014549381694
