The Laguna F1 Fusion Table Saw is a high-quality, reliable machine that consistently delivers stability and power, ensuring excellent performance and dependability with every use.
The F1 Fusion features a large precision ground mirror-finished cast iron tabletop, complemented by additional steel fabricated tables on the left and right, providing an overall table width of 112cm. An MDF rear extension table increases the table depth to 130cm, adding further stability when ripping long lengths. The fully adjustable T-style rip fence with a hi-low sub fence provides flexibility and precision, while the hi-low read out ensures easy and accurate measurements. Powered by a 1.45 kW induction motor, this table saw delivers robust and reliable performance, making it a dependable tool in your workshop.
The F1 takes a 250mm saw blade and provides a maximum cutting depth of 79mm at 90 degrees, enabling deep, precise cuts through thick materials. This is ideal for robust woodworking projects like cutting large panels or thick hardwoods. Additionally, the impressive rip capacity of 760mm allows you to handle wide panels and large sheets of material with ease, providing flexibility and ensuring long, straight cuts with precision and confidence. The hi-low fence adjustment offers versatile cutting options, and the crown guard ensures safety during deep cuts.
Convenience is key with the onboard tool storage, keeping your tools organised and within reach. The all-metal spindle block facilitates quick blade changes, saving you time and effort. The strategically positioned on-off control box allows for effortless access and operation, while the deep rip cut and wide panel crosscut capabilities make handling a variety of cutting tasks easy. The adjustable table tilt and height allow for customised cutting angles with the positive adjusting hand wheels. Dual port extraction ensures efficient dust collection that extracts from above and below the table and has a 100mm take off point, keeping your workspace clean and safe.
One of the standout features of the Laguna F1 Fusion Table Saw are the two smooth blade adjustments hand wheels for the rise and fall and the tilt. The tilt on the blade angle can be easily read off of the large scale on the front of the cabinet. The close clearance phenolic table insert with levelling adjusters ensures a smooth and even surface, enhancing the quality of your cuts. Safety and efficiency are prioritised with the transparent clear crown guard, specially designed for waste clearance.
Investing in the Laguna F1 Fusion Table Saw means equipping your workshop with a tool that combines precision, versatility, and reliability, making it the perfect choice for both entry-level woodworkers and seasoned DIY enthusiasts.
Supplied with; on-board storage points for all the accessories, mitre fence that is hyper accurate when travelling in the T slots, 40 tooth TCT sawblade and quick release riving knife for fast blade changes.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Blade Tilt -3 to 45
Dust Extraction Outlet 100 mm
Max Depth of Cut @ 45º 56 mm
Max Depth of Cut @ 90º 79 mm
Max Width of Cut with Fence 760 mm
Overall L x W x H 1,550 x 1,405 x 1,100 mm
Power 1.45 Kw
Rating Home Workshop
T Slot Size 19 mm & 23 mm
Table Height 887 mm
Blade Diameter 250 mm
Min Extraction Airflow Required 934 m/hr (550 cfm)
Blade RPM 3,800 rpm
Plug Fitted UK 16A Plug
Model F1 Fusion
Bore Size 30 mm
Nett Weight 110 kg
Riving Knife Thickness 2.4 mm
Voltage 230 V
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
EAN Barcode 5052511135288
  • UK Mainland - £70
