The Perform PD254TS Saw Bench is a compact yet powerful solution for home workshops and DIY users. Its solid steel frame construction makes it easy to transport and store, perfect for those with smaller workspaces or mobile setups.
Despite it's compact size, the PD254TS is equipped with a 2kW motor that delivers smooth, consistent power for a wide range of tasks. A soft start feature ensures that motor powers up gradually, reducing noise while making the saw more user-friendly, especially in shared or residential environments.
This saw offers impressive cutting capacity, with a maximum depth of cut of 80mm at 90
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table, for smooth operation.
Supplied with an adjustable mitre fence for angled cuts and a sturdy rip fence for straight, repeatable results, the PD254TS is well-equipped for a variety of woodworking tasks. A push stick is included for added safety and is housed within the integrated tool storage section. Two Teflon blades are included which help prevent resin build up; a 24 tooth ripping blade and a 60 tooth crosscut blade.
Dual 35mm dust extraction ports help to maintain a cleaner working environment when connected to a suitable dust extractor, and the fitted 230V plug means it's ready to go straight out of the box.
