The Perform PD254TS Saw Bench is a compact yet powerful solution for home workshops and DIY users. Its solid steel frame construction makes it easy to transport and store, perfect for those with smaller workspaces or mobile setups.
Despite it's compact size, the PD254TS is equipped with a 2kW motor that delivers smooth, consistent power for a wide range of tasks. A soft start feature ensures that motor powers up gradually, reducing noise while making the saw more user-friendly, especially in shared or residential environments.
This saw offers impressive cutting capacity, with a maximum depth of cut of 80mm at 90 and 50mm at 45. The rip fence allows for up to 300mm of cutting width, which extends to 650mm with the side table extension. With the extensions fitted, the total table width reaches 1,025mm, providing excellent support for larger workpieces. The rip fence locks at the front and back making it super rigid for accurate cuts. The coated aluminium table includes 19mm T-slots on either side of the blade, allowing mitre fences and jigs to slide smoothly for precise, controlled cuts.
The tilt and height adjustment mechanism is bolted to the chassis as opposed to the underside of the table, for smooth operation.
Supplied with an adjustable mitre fence for angled cuts and a sturdy rip fence for straight, repeatable results, the PD254TS is well-equipped for a variety of woodworking tasks. A push stick is included for added safety and is housed within the integrated tool storage section. Two Teflon blades are included which help prevent resin build up; a 24 tooth ripping blade and a 60 tooth crosscut blade.
Dual 35mm dust extraction ports help to maintain a cleaner working environment when connected to a suitable dust extractor, and the fitted 230V plug means it's ready to go straight out of the box.
Please note, if you require an EU plug, please ensure you purchase 113504
Blade Tilt 0 to 45
Dust Extraction Outlet 2 x 35 mm I.D. / 42 mm O.D.
Max Depth of Cut @ 45º 50 mm
Max Depth of Cut @ 90º 80 mm
Max Width of Cut with Fence 300 mm / 650 mm with extension
Overall L x W x H 1,060 x 685 x 495 mm
Power 2.0 kW
Rating Occasional Use
T Slot Size 19 mm x 9.5 mm (3/4" x 3/8")
Table Height 325 mm
Table Size 560 x 680 mm
Blade Diameter 254 mm
Min Extraction Airflow Required 440 m/hr
Blade RPM 4,800 rpm
Plug Fitted UK 3 pin plug
Web Attribute Set Saw Benches
EAN Barcode 5052511142200
