Combining portability and precision, the SawStop Compact Table Saw is the ultimate tool for both job sites and home workshops. As the smallest and most portable saw in the SawStop range, it offers unmatched durability, precision, and power that can be easily transported wherever you work. The exclusive micro-adjust feature ensures the most precise cutting angles possible, while the solid Hi-Low Rack & Pinion Fence guarantees accurate cuts and supports wide rips up to 62cm. With advanced features like a rigid tube structure, rubber feet for stability, and a dust port for efficient dust management, this saw is designed to provide a durable and stable cutting experience. The on-saw storage compartment keeps all necessary tools within easy reach, making it a versatile and convenient choice for any woodworking project. Included components: 1x mitre gauge, 1x brake cartridge (installed), 1x 4mm Hex key, 2x blade wrenches, 1x riving knife (installed), 1x blade guard with spreader, 1x 24-tooth ripping blade (installed), 1x push stick, 1x standard lockdown insert (installed).
SawStop
SawStop CTS Compact Table Saw 230V
| Blade Tilt | 0 to 45 |
| Dust Extraction Outlet | 65 mm |
| Max Depth of Cut @ 45º | 54 mm |
| Max Depth of Cut @ 90º | 79.5 mm |
| Overall L x W x H | 684mm x 597mm x 362mm |
| Power | 1.8 kW |
| Table Height | 362mm |
| Blade Diameter | 254 mm |
| Blade RPM | 4,000 rpm |
| Plug Fitted | 230V - UK BS89/13 13A Type G (2P+Earth) |
| Web Attribute Set | Saw Benches |
| EAN Barcode | 857555005765 |
