The SawStop Jobsite Saw Pro is engineered for durability, innovation, and precision, making it the ideal choice for both job sites and home workshops. This saw is built to withstand tough conditions while providing accurate and reliable cuts. With advanced safety features like skin-detection technology, it ensures user protection. The stable mobile cart allows for easy transport and setup, while the on-saw storage compartment keeps all necessary tools within reach. Whether you're a professional woodworker or a DIY enthusiast, the Jobsite Saw Pro offers unmatched performance and convenience.
Included components: 1x collapsible rolling cart, 1x High/Low T-style fence with Ergolock, 1x mitre gauge, 1x Jobsite Saw Pro Active dust collection blade guard, 1x riving knife, 2x blade wrenches, 1x push stick, 1x 10 blade, 1x zero clearance insert, 1x standard brake cartridge, 1x user's guide, 1x assembly instructions poster, 1x hardware pack, 1x 3mm Hex key, 1x 4mm Hex key, 1x 5mm Hex key
Blade Tilt 0 to 45
Max Depth of Cut @ 45º 54 mm
Max Depth of Cut @ 90º 79.5 mm
Overall L x W x H 736mm x 1219mm x 914mm
Power 2.1 kW
Blade Diameter 254 mm
Blade RPM 4,000 rpm
Plug Fitted 230V - UK BS89/13 13A Type G (2P+Earth)
Bore Size 30 mm
Nett Weight 51kg (113lbs)
Riving Knife Thickness 2.3 mm
Voltage 230 V
Warranty SawStop Warranty Information
EAN Barcode 857555005888
