This is a quality, tough tape housed in an ABS case with a rubber grip that also provides protection against knocks. The white blade has clear black markings in metric graduations on both sides. The end hook allows you to use the tape either way up. This feature is particularly useful when using a pencil to draw a line against the tape. The case has a lock button on the top and a brake on the underside to control the speed of retraction. The case has a wrist /hanging strap and a belt clip.
Manufacturer Part Number 205182
Web Attribute Set Measuring Tapes
EAN Barcode 4014549357675
