The Stanley Closed Case Fibreglass Long Tape has a 13mm wide corrosion resistant, UV protected, non-conductive fibreglass blade. The blade is white and has a washable PVC coating to increase life. The high impact ABS closed case is able to withstand severe work conditions and the case is perforated to allow the tape to be cleaned.
Manufacturer Part Number 3-4-296, 3-4-262
Graduations Metric Only
Tape Length 20 m
Web Attribute Set Measuring Tapes
EAN Barcode 3253560342968
