The STANLEY® FATMAX® XTREME™ Tape Measure is built to meet the demands of professional tradespeople, offering exceptional accuracy and performance across a wide range of applications. Its high-contrast, double-sided black markings on a bright yellow blade ensure excellent visibility, making vertical and overhead measurements quick and precise.
Designed for strength and reliability, it features a rugged, oversized Beast Hook that grips securely to all types of materials. It’s ideal for solo use on the jobsite, helping you work efficiently without compromise.
Durability is at the core of its design, with 16 centimetres of BladeArmor® coating reinforcing the blade for enhanced hook connection and resistance to wear and abrasion. The integrated finger brake offers smooth, controlled retraction and improved handling, giving you total control with every use.
This tape measure includes both metric and imperial graduations, with a 32mm wide blade and EC Class II accuracy—making it a reliable tool for professionals who demand precision and performance.
Tape Length 10 m / 33 ft
Web Attribute Set Measuring Tapes
EAN Barcode 3253565383249
