The Stanley Tylon™; Pocket Tape has a corrosion resistant, long-life Tylon™; coated blade with positive blade lock for accurate measurements. Shows both metric and imperial graduations. Fitted with a Tru-zero hook, that compensates accurately for internal and external measurements, with triple rivet construction for improved strength and durability. The impact resistant ABS plastic case is fitted with an ergonomic overmould for all day comfort.
Manufacturer Part Number 0-30-686N, 1-30-696N, 0-30-656N
Graduations Metric and Imperial
Tape Length 3 m / 10 ft
Web Attribute Set Measuring Tapes
EAN Barcode 3253560306861
