UJK
UJK Moisture Resistant MDF Top for Bench Dogs
SKU: 109827
€110,00
  • For work holding whilst sawing or routing with guide rails
  • Grid of 20mm plain chamfered dog holes
  • Made from moisture resistant MDF
  • Made in the UK
The UJK MRMDF Top for Bench dogs is 18mm thick, moisture resistant MDF. This material is versatile, lightweight and ideal for workshops with varying humidity. The UJK MRMDF top has a grid of 20mm plain chamfered dog holes: 11 holes by 7 holes 96mm apart. These holes are CNC machined to guarantee accuracy, aligned lengthways and widthways with the rows perfectly square to each other. These dog holes allow you to use bench dogs and many other accessory clamps, guide rails and stops to hold, saw, rout and machine your work with perfect accuracy. Made from 18mm thick MRMDF, the 1,102mm x 718mm top fits perfectly in the UJK Multifunction workbench frame or the Festool MFT base. This makes it a suitable replacement for the standard Festool top.
Overall L x W x H 1,102 x 718 x 18mm
Made in Britain Yes
Web Attribute Set Portable Work Benches & Trestles
EAN Barcode 5052511132171
