This connector is used to join two UJK Parf Sticks if the bench being drilled is narrower than the stick. As in cases where a point of the 3:4:5 triangle is overhanging the edge of the bench.
Made in Britain Yes
Intended Use Used in conjunction with the Parf Guide System to produce dog holes.
Web Attribute Set Festool CMS Moduler System and MFT Table Accessories
EAN Barcode 5052511126033
