Festool
Festool CTL 26 EI CLEANTEC Dust Extractor 230V
SKU: 113021
€690,00
  • Suitable for dust with limit values > 1 mg/m³
  • Ideal for both wet and dry extraction
  • L-class is for general work
  • High-performance turbine ensures consistent and powerful suction
  • The permanently installed Bluetooth® interface gives you many options
  • Automatic switch-on/off syncs with power tools for maximum efficiency
  • Large capacity container captures even the finest dust particles
  • Low noise level makes it comfortable to use for extended periods
  • Ergonomic design reduces fatigue and increases productivity
  • Works with a wide range of Festool tools and accessories
The Festool CTL 26 EI CLEANTEC Dust Extractor 230V is a versatile and powerful tool designed for both workshops and construction sites. With its large 26-litre container volume and compact dimensions, this dust extractor offers exceptional performance and convenience. Whether you're using it with corded or cordless tools, the CLEANTEC CTL 26 EI ensures a clean and efficient workspace.
The Festool CTL 26 EI CLEANTEC Dust Extractor 230V offers intuitive touch operation, allowing for simple control of the extractor with an innovative touch panel, even when wearing gloves or in a dirty environment. It features an automatic electrical outlet module that starts up the power tool and automatically activates the extractor for seamless operation.
The adjustable suction power can be set to five levels to suit different applications. Integrated Bluetooth® technology automatically starts the dust extractor via Bluetooth® battery packs or optional remote control, and connects to the Festool app for additional functionality. The convenient T-LOC function allows for easy installation of Systainers, pre-separators, or Workcentres on the mobile dust extractor. The high-performance turbine provides constantly high suction power for efficient dust extraction, while the antistatic function prevents static build-up during work for enhanced safety.
The hose holder and cable winder ensure greater tidiness and safety in your workspace. The smooth suction hose, with its conical geometry, offers high suction power and seamless processes without catching. Large pivoting rollers and an integrated brake provide optimal mobility and stability. The extractor is cost-efficient, with optimal volume usage of the container, and can be upgraded with a compressed-air module or electrical outlet module. It meets safety standards for dust extraction with Dust Category L approval. Additionally, the Bluetooth® functionality allows for remote switch-on for cordless tools and smart connectivity with the Festool app.
Supplied with main filter, SELFCLEAN filter bag, and smooth suction hose diameter 27/32 x 3.5 m AS/CTR.
Please ensure that any dust extractor is suitable for the type of dust produced before ordering. The L-class is for general work. If you are routing/sanding MDF, manmade boards or all solid woods (oak, beech etc), you should use an M-class extractor.
Overall L x W x H 587 x 372 x 539 mm
Corded or Cordless Corded
Cable Length 7.5 m
Max Capacity Dry 26 litre
Airflow Volume 3,900 litre/min
Sound Pressure Level LpA [Uncertainty K] 71 dB(A)
Manufacturer Part Number 577902
Web Attribute Set Power Tool Extractors
EAN Barcode 4014549431276
