A hardwearing water based lacquer, a good alternative to solvent based products. It dries to a very high gloss. Whilst drying, the resin components cross-link to form a coating which is actually tougher than Melamine Lacquer. Apply with brush or roller, allowing two hours between coats. We recommend the use of acrylic sanding sealer first to give a smooth base on which to build the lacquer.
Coverage 8 m to 10 m per litre
Application Method Brush Rag or Cloth
Drying Time 20 minutes
Clean Up Water
Size 1 Litre
Available Sizes 1 litre
Finish Gloss
Web Attribute Set Lacquer, Paint & Varnishes
EAN Barcode 5060095030301
