This finish will give protection against both heat and water. It can be used alone or, for better results, over a cellulose based sanding sealer. Several thin coats provide a superior finish. Quick drying due to cellulose base. The melamine dries to a gloss finish and can then be matted using 0000 Steel Wool, or brought to a gloss by applying wax with a pad of 0000 Steel Wool and buffing to a shine. If brushes are used clean in cellulose thinners..
Coverage 8 m to 10 m per litre
Application Method Brush Rag or Cloth Spray
Drying Time 5 minutes
Clean Up Cellulose Thinners
Available Sizes 400 ml (aerosol)
Web Attribute Set Lacquer, Paint & Varnishes
EAN Barcode 5060095030172
