This Faithfull wire wheel brush is perfect for the removal of rust, corrosion, paint, weld splatter and other general deburring. It is circular, with a 0.3mm crimped steel wire finish. Designed to be mounted on a bench grinder, it is supplied with plastic inserts (bushes) so the wheel can be also mounted on grinders with smaller drive spindles.
Size:150mm x 23mm. Bore: 32mm. Wire: 0.3mm. Conforms to ISO9001 and DIN EN1083-1 and 2.
Web Attribute Set Wire Brushes for Bench Grinders
EAN Barcode 5023969258799
