FISCH have produced an industrial quality brad point (lip and Spur) drill milled from solid stock with a centre point for location and a pair of cutting spurs. The leads ensure accuracy and the deep cut flutes give fast waste removal. Intended for drilling through beams, gate posts and so on, but also most useful when drilling deep holes on the lathe. Length 250mm, spiral length 200mm. N.B. The 12mm has a 10mm diameter shank and a reduced shank length of 30mm. Made in Austria. Supplied in a clear, plastic storage tube for protection and easy access.
Fisch
FISCH Beam Drills
| Drill Bit Diameter | 6.0 mm |
| Overall Length \ Working Length | 250 mm 200 mm |
| L1 | 200mm L2: 250mm Web Attribute Set: Wood Boring Bits |
| EAN Barcode | 9002696134022 |
