Rather than a solid centre point, these bits feature a replaceable centring tip (an exchangeable 4mm pilot drill is available). These Forstner bits cut particularly easily and produce exact tear-free, holes with smooth walls in softwood and hardwood. FISCH forge their multi-functional bits from a single billet, before being CNC ground and then hardened. Accuracy and sharpness are of the highest level. The unique serrated 'Wave' edge produces extremely clean entry holes, allows faster cutting speeds and requires less effort to bore each hole. The shank has 3 flats for secure chucking in a 3-jaw chuck. Spare drill bits are available as are centre tips for drilling blind or straight through holes. These bits are 90mm long overall excluding the pilot drill. Supplied in a clear, plastic storage tube for protection and easy access.
Fisch
FISCH Multi-Function Wave Cutter with Centring Tip
| Drill Bit Diameter | 20 mm |
| Web Attribute Set | Forstner & Sawtooth Cutters |
| EAN Barcode | 9002696337904 |
