Sold out Sale
Axminster Woodturning
Acrylic Kirinite Project Blank - Hot Tan Mop
SKU: 105979
€14,00 €18,00 Save €4,00
  • Acrylic blanks full of eye-catching abstract patterns
  • Rich, shimmering, translucent colours
  • Excellent working properties
  • Easy to turn with sharp tools
  • Larger blanks for project kits
  • Blanks are 64mm long x 42mm square
  • Buffs and polishes to a high gloss finish
Kirinite is a thermoset acrylic resin, specially created for turning and making knife handle scales. It is hardwearing and very durable, easy to work on a lathe and polishes to a brilliant finish. Kirinite features eye-catching abstract patterns running all through the material. It looks stunning when turned bringing out the wealth of colours and patterns inside.
These larger blanks measure 42 x 42 x 64mm and provide plenty of scope for a wide variety of applications; for example, turning larger projects such as bottle stoppers, light-pulls, pendants and knobs. If you have access to a bandsaw, cutting the blank lengthwise into 4 pieces, will give you blanks for 2 pens.
Like many acrylic blanks, the material is hard without being brittle. It is easy to turn with standard turning tools, the sharper the better. Kirinite will finish to a high gloss and has the advantage of not requiring any additional coating to protect it. We recommend the use of our Micro-Mesh abrasives, used wet for finishing.
Additional Accessories No
Blank Dimensions 64 mm x 42 mm x 42 mm
EAN Barcode 5052511116546
