Axminster Woodturning
Axminster Woodturning Cylinder Jaws - 25mm
SKU: 310424
€105,00
  • Potential gripping range: Cylinder 20mm to 38mm
  • Internal and external dovetails on end of jaws
  • Potential gripping range: Internal dovetail 22mm to 40mm
  • Potential gripping range: External dovetail 55mm to 70mm
  • Recommended for GK100, SK100 and SK114 chucks
  • Drawing dimensions taken when jaws form a true circle
  • Cylindrical bore supports long, thin blanks
  • Made in the UK
  • Made from stainless steel to protect against corrosion
When turning long and thin projects it's a great advantage to be able to grip a blank along a substantial amount of its length to impart a good measure of stability to the workpiece. To overcome this problem we have designed these Cylinder Jaws with a 25mm diameter by 49mm long bore to accommodate a range of workpiece diameters. In addition, because we are always loath to provide you with jaws which perform only one function, we have added internal and external dovetails on the ends. Suitable for GK100, SK100 and SK114 chucks only. As with all the Axminster Woodturning Dovetail Jaws they simply bolt onto the Accessory Mounting Jaws. Made from stainless steel to protect against corrosion.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For gripping larger, cylindrical workpieces during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511011919
