When turning long and thin projects it's a great advantage to be able to grip a blank along a substantial amount of its length to impart a good measure of stability to the workpiece. To overcome this problem we have designed these Cylinder Jaws with a 25mm diameter by 49mm long bore to accommodate a range of workpiece diameters. In addition, because we are always loath to provide you with jaws which perform only one function, we have added internal and external dovetails on the ends. Suitable for GK100, SK100 and SK114 chucks only. As with all the Axminster Woodturning Dovetail Jaws they simply bolt onto the Accessory Mounting Jaws. Made from stainless steel to protect against corrosion.
Axminster Woodturning Cylinder Jaws - 25mm
| Made in Britain | Yes |
| Jaws For 100mm Chuck | Yes |
| Jaws For 114mm Chuck | Yes |
| Intended Use | For gripping larger, cylindrical workpieces during woodturning. |
| Web Attribute Set | Jaws for Four Jaw Chucks |
| EAN Barcode | 5052511011919 |
