Axminster Woodturning
Axminster Woodturning Discovery GK88 Dovetail Jaws - Type A
SKU: 111992
€43,00
  • Recommended for the GK88 chuck
  • Ideal for bowls, plates, vases, goblets and more
  • Potential gripping range: External 102mm to 78mm
  • Potential gripping range: Large internal 48mm to 72mm
  • Potential gripping range: Small internal 12mm to 36mm
  • Made in the UK
Axminster Woodturning have recreated some of our most popular jaws in the smaller size to accomodate the 88mm Discovery Chuck.
The Axminster Woodturning Type A Dovetail Jaws are a great general purpose jaw set. Ideal for turning bowls, plates, the internal dovetail will also allow spindle work projects like vases, goblets to be safely held. They offer gripping options: two internal dovetails and one external. The jaws will expand into a 100mm recess and grip onto either 50mm or 26mm diameter spigots. The actual variation is 78mm to 102mm external, 48mm to 72mm internal and 12mm to 36mm smaller internal.
These jaws are designed to fit the GK88 chuck and will simply bolt onto the Accessory Mounting Jaws. All made entirely in the UK.
Please note: the Axminster Woodturning Discovery GK88 range of jaws are compatible with the Discovery GK88 Chuck. They are also compatible with the Discovery GK100, SK100 and Evolution SK114 Chucks, providing the Accessory Mounting Jaws are used (106818).
Intended Use For creating dovetail recesses or spigots during woodturning
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511137220
