Axminster Woodturning
Axminster Woodturning Discovery GK88 Dovetail Jaws - Type E
SKU: 111988
€43,00
  • Recommended for the GK88 chuck
  • Features both an internal and external grip
  • Suitable for a variety of projects
  • Made in the UK
The Axminster Woodturning GK88 Dovetail Jaws - Type E are designed to give you a secure and stable hold of your workpiece. Perfect for anyone new to woodturning, Dovetail Jaws are the most universal jaw and are a great introduction to faceplate rings and screw chucks. The dovetail design provides a strong and reliable grip on the workpiece as it creates multiple points of contact. With enhanced holding power, the risk of the workpiece slipping or shifting during the turning process is greatly reduced.
The GK88 Dovetail Jaws - Type E feature both an internal and external grip, allowing you to safely hold a variety of workpieces of different shapes and sizes. The external dovetail can grip on the inside of a bowl, while the internal dovetail can securely hold the outside of a workpiece, such as a bowl blank or spindle. The potential internal gripping range is 32 - 66mm. The potential external gripping range is 50 - 82mm.
Made entirely in the UK. Compatible with Axminster Woodturning Screw Chuck for E Jaws 111990.
Please note: the Axminster Woodturning Discovery GK88 range of jaws are compatible with the Discovery GK88 Chuck. They are also compatible with the Discovery GK100, SK100 and Evolution SK114 Chucks, providing the Accessory Mounting Jaws are used (106818).
Intended Use For creating dovetail recesses or spigots during woodturning
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511137268
