Axminster Woodturning
Axminster Woodturning Dovetail Jaws Type A Plus
SKU: 506435
€62,00
  • Potential gripping range: Internal 72mm to 93mm
  • Potential gripping range: External 95mm to 116mm
  • Drawing dimensions taken when jaws form true circle
  • Excellent choice of jaws for big bowl turners
  • Made in the UK
  • Made from stainless steel to protect against corrosion
  • Suitable for GK100, SK100 and SK114 Chucks
Dovetail jaws are by far the most secure and most accurate method of holding a bowl or platter on the lathe during turning. Made in Axminster these Dovetail Jaws Type A Plus will grip onto an 80mm diameter 15° dovetailed spigot or expand into a 100mm diameter dovetailed recess. Taken when the jaws form a true circle, the chuck allows a great variation. Internally these jaws can grip 72mm to 93mm and externally expand into a recess from 95mm to 116mm. Please note at more extreme diameters the jaws no longer form a true circle.
These jaws are the same external size as the standard Type A jaws, so are suitable to use with an A Faceplate Ring (500166).
Recommended for the GK00, SK100 and SK114 chucks. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed. Made from stainless steel to protect against corrosion.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For creating dovetail recesses or spigots during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511097180
