Axminster Woodturning
Axminster Woodturning Dovetail Jaws Type B
SKU: 410159
€50,00
  • Potential gripping range: Internal 22mm to 45mm
  • Potential gripping range: External 57mm to 71mm
  • Recommended for GK100, SK100 and SK114 chucks
  • Drawing dimensions taken when jaws form true circle
  • Deep internal dovetail for longer spigots
  • Made in the UK
  • Made from stainless steel to protect against corrosion
The Dovetail Jaws Type B offer expansion into a 62mm recess or compression onto a 25mm dovetailed spigot. These jaws are perfect for small bowls and vases and will cover many a turner’s requirements. The scroll mechanism of an Axminster chuck means there is great variation. Although no longer a true circle, even at the larger diameter the grip remains just as powerful. The Type B jaws have an internal range of 22 to 45mm, and external 57 to 71mm. Recommended for the GK100, SK100 and SK114 chucks. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed. Made from stainless steel to protect against corrosion.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For creating dovetail recesses or spigots during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511020744
