Axminster Woodturning
Axminster Woodturning ER20 Collets for Junior Chuck
SKU: 910209
€13,00
  • Collets for the Axminster junior chuck
  • ER20 engineering collets covering a range of sizes from 6-13mm
  • Collets grip over a diameter range of 1mm without loss of accuracy
  • Arbors and Collet nuts available separately
The Junior chuck is supplied with 7-6mm, 11-10mm and 13-12mm collets; additional collets are also available. Please note: these collets will also fit the Axminster deluxe pen mandrel and the Axminster router collet extension.
These ER20 collets have the unique ability to grip over a diameter range of 1mm without any loss of accuracy. This flexibility means that fewer collets need to be stocked, making them a more economical proposition when compared to other collet-based systems. An additional benefit is that there is no requirement for a separate imperial listing; a 1/4 end mill, for example, will fit into the 7.00mm to 6.00mm collet. Collet nuts are available separately, ideal for customers wishing to make their own holding devices or spindles.
ER Collet Series ER20 Web Attribute Set: Router Collet & Cutter Care
EAN Barcode 5052511043750
