More than thirty-five years ago, Axminster produced and marketed one of the world's first four jaw self centring chucks for woodturners. Over the years, much of the development has come from feedback and input of professional woodturners. With over three decades of experience in production and design, we believe these chucks are the very best on the market today. Manufacturing of the Evolution chucks, jaws and accessories is done entirely in our production facility here in Axminster.
The Evolution SK114 features a super-slim 114mm (4.5) diameter stainless steel body incorporating our SafetyJaw© accessory mounting jaws. The ultra-compact design keeps the workpiece as close as possible to headstock of your lathe to lessen the load on the bearings and prevent unwanted vibration during heavy stock removal. The longer accessory mounting jaws increase the contact area within the slide ways of the chuck, further minimising vibration during use. The Evolution is fully compatible with all accessory jaws. All you need to do is choose the chuck thread to suit your lathe.
The kit gives you the ability to mount bowl blanks for initial turning all the way through to the final completion of a well-executed project; without removing the chuck from your lathe. This kit includes carefully chosen accessories to give you plenty of woodturning potential, it has a set of dovetail jaws (size C), into which you can also mount either the matching faceplate ring or the screw chuck.
Made entirely in Axminster, UK.
Note: 720957 - M33 x 3.5mm chuck is suitable for standard M33 x 3.5mm threads and lathes with an ASR spindle for running in reverse. It has an ASR groove machined on the extended chuck body, which can be used in conjunction with the 109370 ASR Locking Ring (sold separately). This secures the chuck onto the lathe, allowing the lathe to run safely in reverse. If want to run in reverse, you require a lathe with an M33 x 3.5mm EURO standard (ASR) spindle.
Thread Size 1 x 8 tpi
Intended Use Plays a crucial role in securely holding the workpiece on a lathe
Web Attribute Set Woodturning Chucks
EAN Barcode 5052511139347
