Axminster Woodturning
Axminster Woodturning Faceplate Rings
SKU: 500168
€24,00
  • Made to match C dovetail jaws
  • Do away with separate faceplate for mounting bowl blank prior to turning outside
Made to match the C dovetail jaws, these rings do away with the need for a separate faceplate on which to mount a bowl blank prior to turning the outside. Simply screw the ring to the chosen blank with woodscrews and expand the dovetail jaws into the recess in the centre of the ring.
Faceplate Ring C SK100 (500168)
Outer diameter: 100mm, Smaller Inner diameter: 68.5mm, Dovetail angle: 15, Thickness: 10mm
Made in Britain Yes
Intended Use Plays a crucial role in securely holding the workpiece on a lathe.
Web Attribute Set Jaws for Four Jaw Chucks Jaw Type: Type C Dovetail Jaws
EAN Barcode 5052511022311
