Specially designed to give a truly powerful grip, particularly on large diameter parallel pieces. The SK100 Gripper Jaws Type G have a large external dovetail and a serrated inner jaw surface. Externally these are perfect for large platters and bowls, whilst the internal grip holds large hollow forms and end grain pieces. At a true circle, the external jaw is 112mm, the internal 90mm. The chuck’s movement allows for variation between 82mm and 100mm internal grip and 102 to 120mm external grip. At more extreme diameters the jaws no longer form a circle. Recommended for SK100 and SK114 chucks. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed. Made from stainless steel to protect against corrosion.
Axminster Woodturning
Axminster Woodturning Gripper Jaws Type G
| Made in Britain | Yes |
| Jaws For 100mm Chuck | Yes |
| Jaws For 114mm Chuck | Yes |
| Intended Use | For gripping hollow forms or unseasoned wood during woodturning. |
| Web Attribute Set | Jaws for Four Jaw Chucks |
| EAN Barcode | 5052511020812 |
