When larger work is to be turned it is often difficult to get the key down the side of the piece to tighten or loosen the chuck. To overcome this we have produced a 255mm (10
N.B. This key will not fit the Clubman SK100 Chuck.
You're in the right place! To improve the way you shop with us, our website has moved - find out more...
| Made in Britain | Yes |
| Intended Use | Replacement key for tighteng or looseng the woodturning chuck. |
| Chuck Key Type | Fits 9 mm Square Web Attribute Set: Jaws for Four Jaw Chucks |
| EAN Barcode | 5052511025237 |
© Newhow Limited 2026.
VAT No: GB502514046
Company No: 16720753.
