Axminster Woodturning
Axminster Woodturning SK100 Dovetail Jaws - Type E
SKU: 110687
€60,00
  • 100mm Dovetail Jaws -Type E
  • Features both an internal and external grip
  • Suitable for a variety of projects
  • Potential gripping range: Internal 42mm to 60mm
  • Potential gripping range: External 62mm to 82mm
  • Recommended for GK100, SK100 and SK114 chucks
  • Made from stainless steel to protect against corrosion
  • Made entirely in Axminster, UK
The Axminster Woodturning SK100 Dovetail Jaws - Type E are designed to give you a secure and stable hold of your workpiece. Perfect for anyone new to woodturning, Dovetail Jaws are the most universal jaw and are a great introduction to faceplate rings and screw chucks. The dovetail design provides a strong and reliable grip on the workpiece as it creates multiple points of contact. With enhanced holding power, the risk of the workpiece slipping or shifting during the turning process is greatly reduced.
The SK100 Dovetail Jaws - Type E feature both an internal and external grip, allowing you to safely hold a variety of workpieces of different shapes and sizes. The external dovetail can grip on the inside of a bowl, while the internal dovetail can securely hold the outside of a workpiece, such as a bowl blank or spindle
Made from stainless steel to protect against corrosion, these jaws are designed, developed and manufactured entirely in a state-of-the-art manufacturing facility in Axminster, U.K.
Compatible with Axminster Woodturning Screw Chuck for E Jaws 109818.
These jaws are suitable for the GK100, SK100 and SK114 Chucks. If putting 100mm jaws onto the SK114, the additional 100mm accessory mounting jaws will be needed.
Intended Use For creating dovetail recesses or spigots during woodturning.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511133819
