Axminster Woodturning
Axminster Woodturning SK100 Enclosure
SKU: 111982
€54,00
  • Transform your geared Discovery GK100 chuck into a fully enclosed, Discovery SK100 chuck.
  • Made from stainless steel for effective corrosion resistance
  • Made in Axminster, UK using CNC technology for accurate results
The SK100 enclosure is an enclosure that converts your Axminster Woodturning Discovery GK100 chuck into a Discovery SK100 chuck. Your geared GK100 chuck will be transformed into a fully enclosed chuck that uses a square key for positive location in the pinion and for easy operation.
The Discovery SK100 is fully compatible with all previous accessory stainless steel jaws and dovetail jaws.
Made from stainless steel for effective corrosion resistance. Made in Axminster, UK using CNC technology for accurate results.
Please note: To ensure the chuck is assembled safely, secure the chuck front to the chuck backplate (threaded insert) using the 4 x M6 x 25mm screws and ensure they are tightened to 12NM (Newton-Metres). To secure the chuck to the SK100 Enclosure, use the 4 x M4 x 40mm screws and ensure they are tightened to 3.5NM. Please ensure the 2 x M5 Grub Screws are tightened to 2NM. Please ensure the 2 x M5 Grub Screws are tightened to 2NM.
Intended Use Converts your Discovery GK100 chuck into a Discovery SK100 chuck.
Web Attribute Set Woodturning Chucks
EAN Barcode 5052511137329
