Axminster Woodturning
Axminster Woodturning Wood Jaw Plates - 150mm
SKU: 910405
€79,00
  • Provides re-chucking facility to refine the base of bowls
  • Turn self-made custom designed jaws
  • 150mm plates to support larger wooden jaws
  • Pre-drilled steel quadrants
  • Homemade wooden jaws fixed using csk woodscrews
  • Recommended for GK100, SK100 and SK114 chucks
  • Made exclusively by Axminster in Axminster
  • Made from stainless steel to protect against corrosion
Wood jaw plates are a versatile aid for attaching and turning wooden jaws to your own design. Wood Jaw Plates offer an ideal solution for reverse chucking a turned bowl in order to re-work the back or remove any evidence of initial work holding. The SK100 Wood Jaw Plates consist of four pre-drilled steel quadrants. Use standard woodscrews to mount self-made wooden segments. Once attached, these wooden segments turned the wooden jaws to whatever best suits the workpiece. For example, grooves to grip the rim of a bowl. These 150mm plates would be suitable for wooden jaws up to 450mm diameter. An optional long chuck key is available, giving extra reach behind these jaws. Made from stainless steel to protect against corrosion.
Suitable for GK100, SK100 and SK114 chucks. As with all our dovetail jaws, they simply bolt onto the Accessory Mounting Jaws.
Made in Britain Yes
Jaws For 100mm Chuck Yes
Jaws For 114mm Chuck Yes
Intended Use For reverse chucking a turned bowl in order to re-work the back.
Web Attribute Set Jaws for Four Jaw Chucks
EAN Barcode 5052511044672
