Chestnut
Chestnut Food Safe Oil
SKU: 200772
€14,00
  • Gives a non-tainting food safe finish
  • Applies a durable moisture resistant neutral finish
Formulated to give you a non-tainting food safe finish for your wooden projects and turnings. Platters, cheese boards, fruit bowls, chopping and bread boards anything that is in close contact with food. Based on medicinal grade liquid paraffin, this crystal clear oil gives a durable moisture resistant neutral finish that will not impart a smell and will have minimal influence on the colour of your chosen timber when correctly applied. Coverage: 1litre to 6 - 8m. Drying: approximately 2 hours.
Coverage 6 m to 8 m per litre
Application Method Brush Rag or Cloth
Drying Time 2 hours
Clean Up Detergent
Available Sizes 500 ml
Web Attribute Set Oil Finishes
EAN Barcode 5060095030240
